Responsible Use Policy
Last Updated Date: September 14, 2022
Maintaining a high availability of service for all of our customers is a top priority for Golioth. We want all of our customers to have access to the resources they require to rapidly and effectively develop new and innovative products, that means setting in place reasonable policies for the fair use of resources within Golioth. While our service includes broad access to a variety of resources such as time-series data streams and over the air updates, they are not unlimited (unless expressly stated as such) as those services have the potential to degrade the stability of Golioth or disrupt availability for other Golioth customers.
Burst Message Rate refers to the ability to dramatically increase – “burst” -message traffic for up to 60 seconds per hour at specified rate corresponding to your Golioth service tier.
Nominal Message Rate refers to the maximum allowable message rate during non-burst periods.
Outbound Message Data Volume refers to the amount of data transmitted over the air (OTA) from the Golioth cloud to connected devices.
Artifact Storage refers to the software and firmware packages that are stored in the Golioth database.
Our Responsible Use Policy is a part of the Golioth Terms of Use and applies to all customers using the Development, Startup and Standard tiers or custom Golioth Service Tiers derived from these Service Tiers. Limits for Enterprise customers will be customized according to their specific needs.
Terms & Definitions
Message Rate refers to the frequency of both inbound (device to cloud) and outbound (cloud to device) message traffic.Burst Message Rate refers to the ability to dramatically increase – “burst” -message traffic for up to 60 seconds per hour at specified rate corresponding to your Golioth service tier.
Rates & Limits
Burst Message Rate | Nominal Message Rate | Outboard Message Data Volume | Artifact Storage | |
Dev Tier | 4Hz | 1/min | 50 GB | 100 MB |
Startup | 10Hz | 6/min | 200 GB | 1 GB |
Startup 300 | 10Hz | 6/min | 400 GB | 3 GB |
Standard | 20Hz | 12/min | 1.5 TB | 10 GB |
Standard 2500 | 20Hz | 12/min | 3.75 TB | 25 GB |
Standard 5K | 20Hz | 12/min | 7.5 TB | 50 GB |
Standard 10K | 20Hz | 12/min | 15 TB | 100 GB |
Remedial Actions
If your service usage exceeds the limits of your Golioth Service Tier, we will contact you about upgrading your subscription to the next appropriate Service Tier. We may also provide a custom Service Tier, at our sole discretion, if your specific scenario does not fit our standard pricing model.
If your service usage has been exceeding the limits for several months, we will take corrective action, including, but not limited to, throttling your allowable rates and limits, temporarily suspending or—when other options are unavailable—terminating your account.
Please contact our sales team if you need additional information or would like a custom Service Tier quote.
